[Qgis-user] topological editing don't works as expected
Antongeo76
antoviscomi at gmail.com
Wed Oct 17 21:57:46 PDT 2018
Alexandre Neto wrote
> I can confirm that adding a new vertex to a polygon does not create
> vertexes on other other polygons.
> You need to create a node on the other polygon, and then snap it to the
> first. Only then the topological node move work on both polygons.
> Not sure how it worked on 2.18, may be considered a regression.
> Alexandre Neto
> A qua, 17/10/2018, 10:30, Antongeo76 <
> antoviscomi@
> > escreveu:
>> Hi all,
>> in QGIS 3.2.3 as in MASTER
>> I need to edit a polygon shapefile with topological editing active
>> -I set snap options with tolerance 1m to my layer
>> -I active topologica editing an spapping on intersection
>> -I try to add a vertex on a polygon and move it for adjust boundary
>> well
>> -the vertex is added only on one of two coincident polygon boundary
>> -then when I try to move the added vertex this reshape only one of two
>> polygon...
>> I expected that topological editing still works as in QGIS 2,
>> where when I add a vertex and move it the reshaping acts on both
>> polygon who share the boundary I
>> want to reshape
>> there is someone else that has noticed the same anomaly
>> Regards
>> Antonio
>> Antonio
>> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
>> Qgis-user mailing list
> Qgis-user at .osgeo
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Alexandre Neto
> @AlexNetoGeo
> http://sigsemgrilhetas.wordpress.com
> http://gisunchained.wordpress.com
> Qgis-user at .osgeo
In 2.18 adding a vertex on a shared boundary,
This vertex becomes automatically shared too
There is a ticked on qgis issues
https://issues.qgis.org/issues/18046
Regards
Antonio
