[Qgis-user] Supported versions of Geopackage
Stéphane Henriod s at henriod.info
Sun Oct 21 23:49:43 PDT 2018
Hi
This is the info I got from our developer:
This is one of the exceptions you can get
https://osgeo-org.atlassian.net/browse/GEOS-7166(it was reported for
Geoserver 2.7, but is still there in 2.13)
The second exception is on the GeoServer UI, which prevents you to browse
the data store. With version 1.1 or below of GeoPackage after the upload,
if I try to retrieve the datastore I get a not found error, which probably
is correlated to the exception on the UI. This is a consistent error as I
can recreate it every time using the unit tests of our Geoserver client PHP
<https://github.com/OneOffTech/geoserver-client-php/blob/master/tests/Integration/GeoServerDataStoresTest.php#L195>
Geoserver version is 2.13.0
Cheers
Stéphane
On 21 Oct 2018 23:35, "Andrea Aime" <andrea.aime at geo-solutions.it> wrote:
GeoServer developer here (but not GeoPackage store maintainer, mind).
Your statement about the version is a surprise to me, how did you come to
that conclusion?
What kind of error di you get when publishing the gpkg in GeoServer?
And what version of GeoServer are you using?
Cheers
Andrea
Il dom 21 ott 2018, 15:45 Stéphane Henriod <s at henriod.info> ha scritto:
> Dear all
> I have a quick question regarding the support for Geopackage.
> I want to prepare a few geopackages in Qgis and then serve their data as
> WMS from GeoServer. But apparently GeoServer only supports Geopackage
> version 1.2, while Geopackages created with Qgis are an older version.
> Consequence: my layers are not recognized by GeoServer.
> Is this a known problem or is there a trick that I am missing?
> I am desperately trying to get out of the shapefiles but this is currently
> really a blocker for us.
> Thanks a lot in advance for any hints or ideas!
> Cheers
> Stéphane
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181022/efbd0a54/attachment.html>
