[Qgis-user] Supported versions of Geopackage
Andrea Aime
andrea.aime at geo-solutions.it
Sun Oct 28 06:57:38 PDT 2018
On Mon, Oct 22, 2018 at 8:49 AM Stéphane Henriod <s at henriod.info> wrote:
> Hi
> This is the info I got from our developer:
> This is one of the exceptions you can get
> https://osgeo-org.atlassian.net/browse/GEOS-7166(it was reported for
> Geoserver 2.7, but is still there in 2.13)
I could not replicate the same exception with the ERDC WhiteHorse
geopackage, I could configure it fine, but when trying to render it, I got
a failure (but mind, I was using the latest version of GeoServer, not
2.13.x, only had a bit of time to try it out on the branch that I had
handy).
Found indeed an easy to fix bug and prepared a pull request to fix it
(pending review). See details of the issue here:
https://osgeo-org.atlassian.net/browse/GEOT-6164
Not sure I'll have enough time to backport the fix though, it builds on
another change that did not get backported (which probably also explains
the different exception I was seeing). As said, not the maintainer of the
module nor paid to work on this, just trying to get the best out of
very scarce spare time....
Cheers
Andrea
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information. == Ing. Andrea Aime @geowolf Technical Lead
GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39
0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549
http://www.geo-solutions.it http://twitter.com/geosolutions_it
------------------------------------------------------- *Con riferimento
alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 -
Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni
circostanza inerente alla presente email (il suo contenuto, gli eventuali
allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i
destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per
errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le
sarei comunque grato se potesse darmene notizia. This email is intended
only for the person or entity to which it is addressed and may contain
information that is privileged, confidential or otherwise protected from
disclosure. We remind that - as provided by European Regulation 2016/679
“GDPR” - copying, dissemination or use of this e-mail or the information
herein by anyone other than the intended recipient is prohibited. If you
have received this email by mistake, please notify us immediately by
telephone or e-mail.*
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181028/28ecd692/attachment.html>
