[Qgis-user] 3d viewer
Andreas Neumann a.neumann at carto.net
Tue Oct 23 02:38:06 PDT 2018
Hi Emanuele,
Points in QGIS3D must be represented by 3d shapes (box, sphere, model
file, etc.). In each layer there are separate styles for 2D and 3D (each
one in its own separate tab in the layer properties or alternatively in
the styling panel). Did you use the 3D styles? There you can specify the
source of the third dimension (z-coordinate or terrain, absolute or
relative).
Hope this helps,
Andreas
On 2018-10-23 11:13, Emanuele Mele wrote:
> Hi everyone
> I'm trying to plot some point with 3d map in Qgis 3.2 but doesn't work.
> I have added the Z but In the 3d plot the point appear at the same altitude
> Thank you
> Emanuele
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181023/f59f9b33/attachment.html>
