[Qgis-user] 3d viewer
Andreas Neumann
a.neumann at carto.net
Tue Oct 23 10:02:03 PDT 2018
Dear Emanuele,
You don't need to convert anything. Just go to "Layer Properties" -->
"3D View" --> checkbox "Enable 3D Renderer" and select your basic shape
or provide a file with a 3D model (like a tree model, car, etc.). There
you can also select "Altitude clamping".
After these settings, it should "just work".
BTW: don't forget to reply to the "qgis-user at lists.osgeo.org" list.
Please do not communicate with just me, skipping the mailing list.
Greetings,
Andreas
Am 23.10.18 um 15:50 schrieb Emanuele Mele:
> Hi andreas!
> I have converted the point shape to geometry type then set Z value and
> after all I have added geometry attributes.
> xcoord, y coord and zcoord also appear in the attribute table but when
> I enable 3d render doesn't work, they are all flat
> What can I do?
> Thank you!
> Emanuele
> Il mar 23 ott 2018, 11:38 Andreas Neumann <a.neumann at carto.net
> <mailto:a.neumann at carto.net>> ha scritto:
> Hi Emanuele,
> Points in QGIS3D must be represented by 3d shapes (box, sphere,
> model file, etc.). In each layer there are separate styles for 2D
> and 3D (each one in its own separate tab in the layer properties
> or alternatively in
> the styling panel). Did you use the 3D styles? There you can
> specify the source of the third dimension (z-coordinate or
> terrain, absolute or relative).
> Hope this helps,
> Andreas
> On 2018-10-23 11:13, Emanuele Mele wrote:
>> Hi everyone
>> I'm trying to plot some point with 3d map in Qgis 3.2 but doesn't
>> work.
>> I have added the Z but In the 3d plot the point appear at the
>> same altitude
>> Thank you
>> Emanuele
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181023/1db479bf/attachment.html>
