[Qgis-user] qgis - run interpolation on table and selected attribute
Francois Chartier
fra.chartier at gmail.com
Sat Oct 27 14:57:34 PDT 2018
I have a large data set 180k points consisting of XYZ and attribute, and i
would like to interpolate the attribute at certain elevations only.
i have created separate tables for the given elevations outside of qgis and
then imported it and interpolate.
I think that one should be able to run a query and interpolate values based
on the query result, or create a new data set, export query result into a
new table in qgis, and then interpolate. Is this possible?
Thanks,
F
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181027/cc56a33a/attachment.html>
