[Qgis-user] GDAL and https links on qgis
Guy Doulberg
guyd at satellogic.com
Mon Oct 29 07:16:22 PDT 2018
Ok, thanks for the info.
On Mon, Oct 29, 2018 at 3:06 PM Luigi Pirelli <luipir at gmail.com> wrote:
> the main problem is that Windows have only a limited list of thrusted CAs
> in a default installation. Thrusted CA are added atuomatically through a
> remote query to some m$ service when you browse an URl with a WinApi
> capable browser... eg. Explorer (end if I remember well also WinApi)
> So the only way is to "hide" this underground handshake using a adhoc win
> code using WinApi to load CA or using (if it works) CURL.
> So the anwer is... not so simple, and you should thrust the M$ service
> that thrust the CAs. No idea what is the best solution.
> Luigi Pirelli
> * LinkedIn: https://www.linkedin.com/in/luigipirelli
> * Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
> * GitHub: https://github.com/luipir
> * Mastering QGIS 2nd Edition:
> https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
> * Hire me: http://goo.gl/BYRQKg
> On Mon, 29 Oct 2018 at 11:37, Guy Doulberg <guyd at satellogic.com> wrote:
>> Hi
>> I am working on a project that releases big raster imagery,
>> I am trying to create a product that can be used in qgis.
>> The product I had in mind is a raster (VRT) served from the an https
>> endpoint referred by local vrt file
>> I think the issue is relevant to anyone using "/vsicurl/https://..."
>> rasters or even vectors not only vrt.
>> I tested this product on my 3.4 and 2.18 qgis on linux and it worked with
>> no problem
>> But then I tested in on qgis 2.18 and 3.4 on Windows and it turned out
>> there were the following failures:
>> SSL certificate problem: unable to get local issuer certificate
>> It can be fixed by setting CURL_CA_BUNDLE to a certificate bundle either
>> I downloaded from Mozilla site or from the OS itself.
>> Can you think of A more elegant solution? I don't like the idea that I
>> will need to tell my users to hassle with these settings
>> And I don't like the idea of using http, to the data of those products.
>> Maybe that is more a request for the qgis-dev mailing list, but is there
>> a way to compile qgis with gdal that already has all the certificates
>> authorities?
>> Thanks, Guy
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181029/5c674ff6/attachment.html>
