[Qgis-user] GDAL and https links on qgis
Luigi Pirelli luipir at gmail.com
Mon Oct 29 06:06:04 PDT 2018
the main problem is that Windows have only a limited list of thrusted CAs
in a default installation. Thrusted CA are added atuomatically through a
remote query to some m$ service when you browse an URl with a WinApi
capable browser... eg. Explorer (end if I remember well also WinApi)
So the only way is to "hide" this underground handshake using a adhoc win
code using WinApi to load CA or using (if it works) CURL.
So the anwer is... not so simple, and you should thrust the M$ service that
thrust the CAs. No idea what is the best solution.
Luigi Pirelli
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS 2nd Edition:
https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
* Hire me: http://goo.gl/BYRQKg
On Mon, 29 Oct 2018 at 11:37, Guy Doulberg <guyd at satellogic.com> wrote:
> Hi
> I am working on a project that releases big raster imagery,
> I am trying to create a product that can be used in qgis.
> The product I had in mind is a raster (VRT) served from the an https
> endpoint referred by local vrt file
> I think the issue is relevant to anyone using "/vsicurl/https://..."
> rasters or even vectors not only vrt.
> I tested this product on my 3.4 and 2.18 qgis on linux and it worked with
> no problem
> But then I tested in on qgis 2.18 and 3.4 on Windows and it turned out
> there were the following failures:
> SSL certificate problem: unable to get local issuer certificate
> It can be fixed by setting CURL_CA_BUNDLE to a certificate bundle either
> I downloaded from Mozilla site or from the OS itself.
> Can you think of A more elegant solution? I don't like the idea that I
> will need to tell my users to hassle with these settings
> And I don't like the idea of using http, to the data of those products.
> Maybe that is more a request for the qgis-dev mailing list, but is there a
> way to compile qgis with gdal that already has all the certificates
> authorities?
> Thanks, Guy
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181029/1e638335/attachment.html>
