[Qgis-user] geopackage spatial query
Mithoefer
mithoefer at gbd-consult.de
Tue Oct 30 00:08:54 PDT 2018
Dear all,
thanks a lot for all your replies. They were all very helpful to me!
Am 29.10.18 um 20:47 schrieb Bo Victor Thomsen:
> Hi Klaus -
> Even though the GeoPackage format is using a spatialite database as the
> foundation, the internal format of the geopackage geometry type differs
> from the spatialite type. So yon can't directly use spatialite geometry
> based function with geopackage geometries.
> However you can "wrap" every use of GeoPackage geometries in a converter
> function: *CastAutomagic(geom)*, which converts a GeoPackage geometry to
> a Spatialite geometry.
> So a call to: /st_area (geom)/ becomes /st_area(*CastAutomagic(*geom*)*)/
> (No, It's not nice and it certainly not effective use of computer
> resources, however it works.)
> There is a thread about the why's and why-not's for this subject in the
> QGIS-user list around september 13 , 2018
> Regards
> Bo Victor Thomsen
> LIFA Landinspektører A/S,
> Denmark
> Den 29/10/2018 kl. 14.35 skrev Mithoefer:
>> Dear List,
>> I have a geopackage database and tried to use a spatial sql function
>> (st_area) using the db manager in qgis 3.4 --> select st_area(geom)
>> from polygon_filename. The function is available, but the result is
>> Null. What is the problem?
>> Thanks a lot
>> Kind regards
>> Klaus
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
