[Qgis-user] QGIS 3.4 macOS still doesn't install GRASS properly, ... 'sigh...'
    Ian Turton
    ijturton at gmail.com
    Wed Oct 31 10:30:24 PDT 2018
To be fair you can't run ESRI on a mac either, but this is basically a put
up or shut up issue - hire a developer to fix the mac build if you can't do
it your self.
Ian
On Wed, 31 Oct 2018 at 17:27, Mr. Stace D Maples <stacemaples at stanford.edu>
wrote:
> Seriously, we just can’t get a working installer for macOS? It’s just
> never gonna happen, is that it? I’d love to be able to teach QGIS alongside
> Esri, but I can tell people to use something that doesn’t work, out of the
> box. I’ve been trying for 2 days now to get back to a working copy of
> QGIS3. It’s my fault, of course. I know better than to upgrade, now.  If
> you aren’t going to test it properly, don’t release it.
> Here is what I get when running GRASS tools:
> 2018-10-31T08:54:25     INFO    GRASS GIS 7 execution console output
>          WARNING: Default locale settings are missing. GRASS running with
> C locale.
>          Starting GRASS GIS...
>          ERROR: Path '//' doesn't exist
>          Default locale not found, using UTF-8
>          Exiting...
> C locale.
>          Exiting...
> Yes, I read the ReadMe and followed the instructions
> Yes, I’ve added the ENV variables
> Yes, I’ve scrubbed everything and done a clean install (several times)
> Yes, I even tried the futile installation of the GRASS “required
> frameworks” which seem to be the only solutions anyone is able to suggest
> on StackExchange.
> Yes I tried installing GRASS on it’s own and pointing to it from the
> processing settings, which didn’t work.
> Perfectly open to suggestions that DON’T involve any of the above.
> In F,L&T,
> Stace Maples
> Geospatial Manager
> Stanford Geospatial Center
> @mapninja
> G+, Skype, Hangout: stacey.maples
> 214.641.0920
> Find GeoData: https://earthworks.stanford.edu
> Get GeoHelp: https://gis.stanford.edu/
> stanfordgis Listserv:
> https://mailman.stanford.edu/mailman/listinfo/stanfordgis
> "I have a map of the United States... actual size.
> It says, "Scale: 1 mile = 1 mile."
> I spent last summer folding it."
> -Steven Wright-
> Qgis-user mailing list
Ian Turton
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181031/f288eb87/attachment.html>
