[Qgis-user] Problem with quick map service plugin
Alex M
tech_dev at wildintellect.com
Wed Oct 31 13:05:34 PDT 2018
On 10/31/18 08:12, GobaA wrote:
> Greetings
> I have a problem with quick map service plugin for accessing google satellite maps, whenever I am trying to install it, the reply message displays that there is an error in loading plugin and I must contact the author (Please see the screen capture attached). Kindly help solving this problem.
> Regards
> Ayanda A Goba
> Resource Auditor: King Cetshwayo District & EThekwini Municipality
> Department: Agriculture, Forestry & Fisheries (Land Use and Soil Management)
> T: 033 345 3515/57 - F: 033 394 6161 - M: 082 523 6501 - E:GobaA at daff.gov.za
> "IGAMA LAKHO JESU LIHLE"
> [cid:image003.jpg at 01D4713C.D5316E70]
What operating system are you on and which installation method did you
use? It appears that your python installation is missing the requests
library. You will need to add this. Installation method will vary
depending the answer to my first question.
Thanks,
Alex
