[Qgis-user] can not open nc file
Saber Razmjooei
saber.razmjooei at lutraconsulting.co.uk
Sun Sep 2 00:43:27 PDT 2018
We are planning to add netcdf as mesh layer in MDAL.
For the time being, you can convert your netcdf to grib using CDO
sudo apt-get install cdo
and then convert it to GRIB using:
cdo -v -f grb -copy INPUT.nc OUTPUT.grb
You then need to add the grib file as a mesh layer from QGIS Browser.
Stay tuned and with some luck, we might be able to add netcdf as a mesh
layer in the next QGIS release.
https://github.com/lutraconsulting/MDAL/issues/22
Regards
Saber
On Wed, 29 Aug 2018 at 23:06, Antonio Silva <aolinto.lst at gmail.com> wrote:
> Hello,
> I'm used to load sea surface temperature (and others) nc files from Ocean
> Color Web (https://oceancolor.gsfc.nasa.gov/cgi/l3) in QGis.
> But today I tried to load one file and I received the warning "Raster
> layer: Provider is not valid (provider: gdal..."
> I'm using QGIS 3.2.2 under Ubuntu 18.04 64 bits. The same file could be
> opened in other computer running an older qgis.
> Does anyone know how to work around this problem?
> Thanks
> Antônio Olinto Ávila da Silva
> Instituto de Pesca (Fisheries Institute)
> São Paulo, Brasil
> Qgis-user mailing list
Saber Razmjooei
www.lutraconsulting.co.uk
+44 (0)7568 129733
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180902/902d918c/attachment.html>
