[Qgis-user] can not open nc file
Antonio Silva
aolinto.lst at gmail.com
Tue Sep 11 18:16:15 PDT 2018
Dear Saber
I will try this. Thanks a lot. I hope you can finish the job soon.
Good luck
Antonio Olinto
Em dom, 2 de set de 2018 às 04:43, Saber Razmjooei <
saber.razmjooei at lutraconsulting.co.uk> escreveu:
> We are planning to add netcdf as mesh layer in MDAL.
> For the time being, you can convert your netcdf to grib using CDO
> sudo apt-get install cdo
> and then convert it to GRIB using:
> cdo -v -f grb -copy INPUT.nc OUTPUT.grb
> You then need to add the grib file as a mesh layer from QGIS Browser.
> Stay tuned and with some luck, we might be able to add netcdf as a mesh
> layer in the next QGIS release.
> https://github.com/lutraconsulting/MDAL/issues/22
> Regards
> Saber
> On Wed, 29 Aug 2018 at 23:06, Antonio Silva <aolinto.lst at gmail.com> wrote:
>> Hello,
>> I'm used to load sea surface temperature (and others) nc files from
>> Ocean Color Web (https://oceancolor.gsfc.nasa.gov/cgi/l3) in QGis.
>> But today I tried to load one file and I received the warning "Raster
>> layer: Provider is not valid (provider: gdal..."
>> I'm using QGIS 3.2.2 under Ubuntu 18.04 64 bits. The same file could be
>> opened in other computer running an older qgis.
>> Does anyone know how to work around this problem?
>> Thanks
>> Antônio Olinto Ávila da Silva
>> Instituto de Pesca (Fisheries Institute)
>> São Paulo, Brasil
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Saber Razmjooei
> www.lutraconsulting.co.uk
> +44 (0)7568 129733
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180911/cb53264b/attachment.html>
