[Qgis-user] "Official" QGIS Web Client?
Andreas Neumann
a.neumann at carto.net
Mon Sep 3 01:36:59 PDT 2018
Hi Chris,
>From these three clients you mention, I would currently only consider
QWC2. It is now in a good state and deployed in several provinces and
cities as production version. Already now, QWC2 has exceeded the
functionality of QWC1 and it is based on modern, up-to-date libraries
and responsive. Also, QWC2 is actively in development.
The demo application is not because QWC2 is not in production state, but
it should help you to get a start project.
QWC1, and I assume EQWC is based on old versions of OpenLayers and not
fully responsive.
As Paolo mentioned, there is also Lizmap.
In your case, I would evaluate QWC2 and Lizmap.
Greetings,
Andreas
On 2018-09-03 04:33, Christopher Gray wrote:
> I've found 3 QGIS related web clients:
> QGIS Web Client (QWC1)
> QGIS Web Client 2 (QWC2)
> Enhanced QGIS Web Client (EQWC)
> The QGIS website still references QWC1, while the QWC1 page says it is no longer maintained and suggests QWC2. The QWC2 page lists itself as a "demo application" which seems to suggest it is in-progress, but perhaps I am misinterpreting this. The EQWC page looks like a functioning option but suggests it is based on QWC1 which I understand was considered outdated...
> EQWC seems to perform nicely (based on their demo maps), and has user and guest authentication which seems very important for map access.
> Anyhow, which of these is considered the current "QGIS Web Client" / most appropriate to use at this time?
> [In my specific situation, this will be my first web-client setup. I'm preparing to setup a publicly available map for my town and a private map for my family farm in the town (That will require authentication to access).]
> Thank you, Chris
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180903/955ba034/attachment.html>
