[Qgis-user] "Official" QGIS Web Client?
Leonardo Lami
lami at gis3w.it
Tue Sep 4 00:22:08 PDT 2018
Hi Chris,
you can also evaluate G3W-SUITE, a framework developed in DJango to
publish and manage your QGIS projects.
You can find info here:https://g3wsuite.gis3w.it/en/
<https://g3wsuite.gis3w.it/en/>
Manual and demo here: https://g3wsuite.gis3w.it/en/g3wsuite-demo/
And here the GitHub repository: https://github.com/g3w-suite
Greetings
Leonardo
Il 03/09/2018 22:12, Christopher Gray ha scritto:
> Andreas,
> Thank you for the description, I have taken some more time to look
> into both QWC2 and Lizmap. QWC2 seems very nice [although I would like
> if the menu remained showing on the larger screens.] I have a tendency
> to want to use QWC2 since it is intended to integrate with QGIS
> projects and appears to be in development alongside QGIS, but Lizmap
> is very nice as well.
> Do you happen to know if QWC2 has any authentication features yet?
> Thank you, Chris
> On Mon, Sep 3, 2018 at 4:36 AM Andreas Neumann <a.neumann at carto.net
> <mailto:a.neumann at carto.net>> wrote:
> Hi Chris,
> From these three clients you mention, I would currently only
> consider QWC2. It is now in a good state and deployed in several
> provinces and cities as production version. Already now, QWC2 has
> exceeded the functionality of QWC1 and it is based on modern,
> up-to-date libraries and responsive. Also, QWC2 is actively in
> development.
> The demo application is not because QWC2 is not in production
> state, but it should help you to get a start project.
> QWC1, and I assume EQWC is based on old versions of OpenLayers and
> not fully responsive.
> As Paolo mentioned, there is also Lizmap.
> In your case, I would evaluate QWC2 and Lizmap.
> Greetings,
> Andreas
> On 2018-09-03 04:33, Christopher Gray wrote:
>> I've found 3 QGIS related web clients:
>> QGIS Web Client (QWC1)
>> QGIS Web Client 2 (QWC2)
>> Enhanced QGIS Web Client (EQWC)
>> The QGIS website still references QWC1, while the QWC1 page says
>> it is no longer maintained and suggests QWC2. The QWC2 page lists
>> itself as a "demo application" which seems to suggest it is
>> in-progress, but perhaps I am misinterpreting this. The EQWC page
>> looks like a functioning option but suggests it is based on QWC1
>> which I understand was considered outdated...
>> EQWC seems to perform nicely (based on their demo maps), and has
>> user and guest authentication which seems very important for map
>> access.
>> Anyhow, which of these is considered the current "QGIS Web
>> Client" / most appropriate to use at this time?
>> [In my specific situation, this will be my first web-client
>> setup. I'm preparing to setup a publicly available map for my
>> town and a private map for my family farm in the town (That will
>> require authentication to access).]
>> Thank you, Chris
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180904/ef20282b/attachment.html>
