[Qgis-user] "Official" QGIS Web Client?
Kari Salovaara
kari.salovaara at pp1.inet.fi
Tue Sep 4 01:43:52 PDT 2018
Hi Leonardo,
interesting and promising project.
If I understand collectly You have the possibility to localize the user
interfaces, how are You planning to do it by crowdsourcing?
Cheers, Kari
Leonardo Lami kirjoitti 4.9.2018 klo 10:22:
> Hi Chris,
> you can also evaluate G3W-SUITE, a framework developed in DJango to
> publish and manage your QGIS projects.
> You can find info here:https://g3wsuite.gis3w.it/en/
> <https://g3wsuite.gis3w.it/en/>
> Manual and demo here: https://g3wsuite.gis3w.it/en/g3wsuite-demo/
> And here the GitHub repository: https://github.com/g3w-suite
> Greetings
> Leonardo
> Il 03/09/2018 22:12, Christopher Gray ha scritto:
>> Andreas,
>> Thank you for the description, I have taken some more time to look
>> into both QWC2 and Lizmap. QWC2 seems very nice [although I would
>> like if the menu remained showing on the larger screens.] I have a
>> tendency to want to use QWC2 since it is intended to integrate with
>> QGIS projects and appears to be in development alongside QGIS, but
>> Lizmap is very nice as well.
>> Do you happen to know if QWC2 has any authentication features yet?
>> Thank you, Chris
>> On Mon, Sep 3, 2018 at 4:36 AM Andreas Neumann <a.neumann at carto.net
>> <mailto:a.neumann at carto.net>> wrote:
>> Hi Chris,
>> From these three clients you mention, I would currently only
>> consider QWC2. It is now in a good state and deployed in several
>> provinces and cities as production version. Already now, QWC2 has
>> exceeded the functionality of QWC1 and it is based on modern,
>> up-to-date libraries and responsive. Also, QWC2 is actively in
>> development.
>> The demo application is not because QWC2 is not in production
>> state, but it should help you to get a start project.
>> QWC1, and I assume EQWC is based on old versions of OpenLayers
>> and not fully responsive.
>> As Paolo mentioned, there is also Lizmap.
>> In your case, I would evaluate QWC2 and Lizmap.
>> Greetings,
>> Andreas
>> On 2018-09-03 04:33, Christopher Gray wrote:
>>> I've found 3 QGIS related web clients:
>>> QGIS Web Client (QWC1)
>>> QGIS Web Client 2 (QWC2)
>>> Enhanced QGIS Web Client (EQWC)
>>> The QGIS website still references QWC1, while the QWC1 page says
>>> it is no longer maintained and suggests QWC2. The QWC2 page
>>> lists itself as a "demo application" which seems to suggest it
>>> is in-progress, but perhaps I am misinterpreting this. The EQWC
>>> page looks like a functioning option but suggests it is based on
>>> QWC1 which I understand was considered outdated...
>>> EQWC seems to perform nicely (based on their demo maps), and has
>>> user and guest authentication which seems very important for map
>>> access.
>>> Anyhow, which of these is considered the current "QGIS Web
>>> Client" / most appropriate to use at this time?
>>> [In my specific situation, this will be my first web-client
>>> setup. I'm preparing to setup a publicly available map for my
>>> town and a private map for my family farm in the town (That will
>>> require authentication to access).]
>>> Thank you, Chris
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180904/35fed0e4/attachment.html>
