[Qgis-user] Plugin ArrayPlus in conflit with QGIS 3.3
Etienne Trimaille
etienne.trimaille at gmail.com
Mon Sep 17 05:53:12 PDT 2018
I think you shouldn't mark it as deprecated until all functions are in QGIS
core.
Indeed, https://github.com/qgis/QGIS/pull/7645 won't be merged until 3.6,
the feature freeze is ON since friday for 3.4.
If I were you, I would still release the plugin with 3.0 minimum verison
and add something like "if Qgis.QGIS_VERSION_INT
<https://qgis.org/api/classQgis.html#a599a850991eeb103d08d7954439df9d4> <
30300: register foo()" according to the current QGIS version.
About array_lambda, there is now array_foreach in QGIS core using an
expression.
Le lun. 17 sept. 2018 à 04:15, Jean-Baptiste Desbas <jb.desbas at gmail.com> a
écrit :
> Hello,
> I am maintener of ArrayPlus plugin (
> https://plugins.qgis.org/plugins/arrayplus/)
> Since QGIS 3.3 includes "hstore_to_map" and "json_to_map" functions, the
> ArrayPlus plugin is in conflit with QGIS 3.3. (
> https://framagit.org/jbdesbas/arrayPlus/issues/2 )
> Tough, I'm not sur that others functions (array_avg, array_min, etc..)
> will be in the QGIS core (https://github.com/qgis/QGIS/pull/7645).
> So what is the proper thing to do ?
> Release a new version of the plugin without "hstore_to_map"/"json_to_map"
> and with minimum QGIS version 3.3 ?
> Mark the plugin as deprecated ?
> Thanks,
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180917/294af474/attachment.html>
