[Qgis-user] Plugin ArrayPlus in conflit with QGIS 3.3
Jean-Baptiste Desbas jb.desbas at gmail.com
Mon Sep 17 22:51:22 PDT 2018
OK thanks ! I'll do that !
Le lun. 17 sept. 2018 à 14:53, Etienne Trimaille <
etienne.trimaille at gmail.com> a écrit :
> Hi,
> I think you shouldn't mark it as deprecated until all functions are in
> QGIS core.
> Indeed, https://github.com/qgis/QGIS/pull/7645 won't be merged until 3.6,
> the feature freeze is ON since friday for 3.4.
> If I were you, I would still release the plugin with 3.0 minimum verison
> and add something like "if Qgis.QGIS_VERSION_INT
> <https://qgis.org/api/classQgis.html#a599a850991eeb103d08d7954439df9d4> <
> 30300: register foo()" according to the current QGIS version.
> About array_lambda, there is now array_foreach in QGIS core using an
> expression.
> Le lun. 17 sept. 2018 à 04:15, Jean-Baptiste Desbas <jb.desbas at gmail.com>
> a écrit :
>> Hello,
>> I am maintener of ArrayPlus plugin (
>> https://plugins.qgis.org/plugins/arrayplus/)
>> Since QGIS 3.3 includes "hstore_to_map" and "json_to_map" functions, the
>> ArrayPlus plugin is in conflit with QGIS 3.3.  (
>> https://framagit.org/jbdesbas/arrayPlus/issues/2 )
>> Tough, I'm not sur that others functions (array_avg, array_min, etc..)
>> will be in the QGIS core (https://github.com/qgis/QGIS/pull/7645).
>> So what is the proper thing to do ?
>> Release a new version of the plugin without "hstore_to_map"/"json_to_map"
>> and with minimum QGIS version 3.3 ?
>> Mark the plugin as deprecated ?
>> Thanks,
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180918/237ca92c/attachment.html>
