[Qgis-user] Mac OS X QGIS 3.2.2 install -Python 3.7.0
    DT
    dmofot at gmail.com
    Wed Sep 19 04:10:54 PDT 2018
No need to uninstall your system python 2.7. When you install python 3.6.6,
it will get mapped to “python3”. One note, if you pre-install some of the
python packages, you’ll want to use “pip3” to make sure it installs into
python 3.6.6.
DT
On Wed, Sep 19, 2018 at 6:58 AM nwastra <nwastra at gmail.com> wrote:
> Thanks Jesus. Should I uninstall Python 2.7 first? If so do I just delete
> it’s folder?
> Nev
> > On 19 Sep 2018, at 7:29 pm, Jesús Lopez <jesusl.temez at gmail.com> wrote:
> > You can download Python 3.6.6 from <
> https://www.python.org/downloads/release/python-366/>. It’s totally
> discouraged install 3.7.x.
> > Regards.
> >> El 18 sept 2018, a las 8:09, nwastra <nwastra at gmail.com> escribió:
> >> Hi
> >> I notice this advice in QGIS-macOS-3.2.2-1.dmg
> >> Python 3.6 must be installed first!
> >> Install at least 3.6.5, the macOS 10.9 build.
> >> (previous versions did not hav a 10.9 build)
> >> Only python.org Python 3 is supported.
> >> Make sure to use the default/standard install (or at least the install
> pip option in a custom install)
> >> When I go to the Python 3.6 link https://www.python.org/downloads/  I
> am offered Python 3.7.0
> >> Advice is not clear for me.
> >> Is it ok to download 3.7.0 instead of 3.6 (it is at least at least
> 3.6.5)?
> >> Tks
> >> Nev
> >> _______________________________________________
> >> Qgis-user mailing list
> >> Qgis-user at lists.osgeo.org
> >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180919/0c85fe76/attachment-0001.html>
