[Qgis-user] Mac OS X QGIS 3.2.2 install -Python 3.7.0
Jesús Lopez jesusl.temez at gmail.com
Wed Sep 19 04:11:17 PDT 2018
It’s not necessary. Both versions can be installed at same time and OS X use Python 2.7 so you should not uninstall it.
Regards
> El 19 sept 2018, a las 12:57, nwastra <nwastra at gmail.com> escribió:
> Thanks Jesus. Should I uninstall Python 2.7 first? If so do I just delete it’s folder?
> Nev
>> On 19 Sep 2018, at 7:29 pm, Jesús Lopez <jesusl.temez at gmail.com> wrote:
>> You can download Python 3.6.6 from <https://www.python.org/downloads/release/python-366/>. It’s totally discouraged install 3.7.x.
>> Regards.
>>> El 18 sept 2018, a las 8:09, nwastra <nwastra at gmail.com> escribió:
>>> Hi
>>> I notice this advice in QGIS-macOS-3.2.2-1.dmg
>>> Python 3.6 must be installed first!
>>> Install at least 3.6.5, the macOS 10.9 build.
>>> (previous versions did not hav a 10.9 build)
>>> Only python.org Python 3 is supported.
>>> Make sure to use the default/standard install (or at least the install pip option in a custom install)
>>> When I go to the Python 3.6 link https://www.python.org/downloads/  I am offered Python 3.7.0
>>> Advice is not clear for me.
>>> Is it ok to download 3.7.0 instead of 3.6 (it is at least at least 3.6.5)?
>>> Tks
>>> Nev
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
