[Qgis-user] Java and QGIS
Andrea Aime
andrea.aime at geo-solutions.it
Mon Sep 24 07:58:23 PDT 2018
On Mon, Sep 24, 2018 at 4:49 PM Tyler Veinot <tylerkveinot at gmail.com> wrote:
> Ok, so since I am using QGIS, QGIS Server, and Lizmap setup via these
> directions
> https://opengislab.com/blog/2018/7/7/updated-installing-apache-qgis-server-and-lizmap-on-windows-os
> this setup is unaffected because it is running on Apache?
> But my setup using Tomcat with GeoServer is going to have issues in the
> future?
No issues, GeoServer is a server side Java implementation that will be
supported in the future too, along with server side Java.
The issue is with Java in the browser, but GeoServer makes no use of it.
Cheers
Andrea
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information. == Ing. Andrea Aime @geowolf Technical Lead
GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39
0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549
http://www.geo-solutions.it http://twitter.com/geosolutions_it
------------------------------------------------------- *Con riferimento
alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 -
Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni
circostanza inerente alla presente email (il suo contenuto, gli eventuali
allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i
destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per
errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le
sarei comunque grato se potesse darmene notizia. This email is intended
only for the person or entity to which it is addressed and may contain
information that is privileged, confidential or otherwise protected from
disclosure. We remind that - as provided by European Regulation 2016/679
“GDPR” - copying, dissemination or use of this e-mail or the information
herein by anyone other than the intended recipient is prohibited. If you
have received this email by mistake, please notify us immediately by
telephone or e-mail.*
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180924/46175f74/attachment.html>
