[Qgis-user] Java and QGIS
Tyler Veinot
tylerkveinot at gmail.com
Tue Sep 25 07:37:02 PDT 2018
Thank you all again for the additional info, this will certainly help me
better understand and implement these programs to show my organisation what
GIS and open source GIS can do.
Thanks again for the support.
Tyler
On Mon, Sep 24, 2018 at 12:43 PM Nicolas Boisteault <
nicolas.boisteault at arb-na.fr> wrote:
> Yes it is confusing. Only Apache Tomcat depends on Java. When someone
> speaks about Apache he is refering to Apache HTTP Server which doesn't need
> Java to run.
> Le 24/09/2018 à 16:48, Tyler Veinot a écrit :
> Ok, so since I am using QGIS, QGIS Server, and Lizmap setup via these
> directions
> https://opengislab.com/blog/2018/7/7/updated-installing-apache-qgis-server-and-lizmap-on-windows-os
> this setup is unaffected because it is running on Apache?
> But my setup using Tomcat with GeoServer is going to have issues in the
> future?
> I apologize for the confusion, I thought Apache and Apache Tomcat were
> flavors of the same thing; I thought they both depended on Java
> environments to run.
> Tyler
> On Mon, Sep 24, 2018 at 11:15 AM Régis Haubourg <regis.haubourg at gmail.com>
> wrote:
>> Hi,
>> QGIS has nothing to do with Java. QGIS server can be run using Apache
>> (not TOMCAT) or nginx and shouldn't be at all concerned.
>> Regards,
>> Régis
>> Le lun. 24 sept. 2018 à 16:11, Tyler Veinot <tylerkveinot at gmail.com> a
>> écrit :
>>> Hi All;
>>> So my IT guy said that Java is being phased out and is no longer
>>> supported on many browsers and soon none. I have JRE and JDK setup as part
>>> of Apachie and Tomcat Services for running web maps using; Lizmap,
>>> GeoServer, QGIS/QGIS Server, and we have been looking at setting up a web
>>> map server using these technologies. Now I am wondering if I should look
>>> for another web server applet that does use Java or if it is a non-issue.
>>> I guess my question is with Java being phased out/not supported what do
>>> we turn to for a web server in the opensource GIS community?
>>> Thanks;
>>> Tyler
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Qgis-user mailing listQgis-user at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180925/97e06d84/attachment.html>
