[Qgis-user] Hot Spot Accumulation
    GILLEN Finbar
    finbar.gillen at axa.ie
    Thu Sep 27 04:53:38 PDT 2018
Hi Nicolas,
I checked that but it doesn’t create a singular circle for each point. In more dense areas it will merge the circles as one.
I would be looking for an individual circle for each point.
Regards
Finbar
From: Nicolas Cadieux <nicolas.cadieux at archeotec.ca>
Sent: 27 September 2018 12:51
To: GILLEN Finbar <finbar.gillen at axa.ie>
Cc: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Hot Spot Accumulation
I believe heat map will do that. You can use weight from field.
http://www.qgistutorials.com/fr/docs/creating_heatmaps.html
Nicolas
Le 27 sept. 2018 à 07:42, GILLEN Finbar <finbar.gillen at axa.ie<mailto:finbar.gillen at axa.ie>> a écrit :
Hi All,
Is there a plugin or tool within QGIS that creates a hotspot for each individual point in a dataset and assigns a score based on the amount of points that fall within a given radius, say 200 metres (See image below)?
<image001.png>
I would be looking to weight the score with a variable within the dataset to.
Regards
Finbar
The contents and any attachments of this electronic mail message are confidential and intended only for the named addressees. Dissemination, forwarding, publication or other use of the message or attachments by any unauthorised person is strictly prohibited.
Unless stated to the contrary, any opinions expressed in this message are personal and may not be attributed to AXA Insurance dac or any member of the AXA Group of Companies.
AXA Insurance dac is regulated by the Central Bank of Ireland. For business in Northern Ireland, AXA Insurance dac is authorised by the Central Bank of Ireland and subject to limited regulation by the Financial Conduct Authority. Details about the extent of our regulation by the Financial Conduct Authority are available from us on request. AXA Insurance dac is a private company limited by shares, registered in Ireland number 136155. Registered Office Wolfe Tone House, Wolfe Tone Street, Dublin 1.
"AXA Supporting Road Safety in Ireland"
Internet e-mails are not necessarily secure. AXA Group does not accept responsibility for changes made to this message after it was sent. To help promote the use of electronic documents and to be kinder to the environment, please consider whether you really need to print this
email.
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
email.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180927/b4271733/attachment.html>
