[Qgis-user] QGIS 3.2.3 on MacOSX unstable, have to re-install
Andrew Grant-Adamson
andrew at grant-adamson.me.uk
Fri Sep 28 09:29:56 PDT 2018
I have a similar set up QGIS 3.2.2 on mac 10.13.6 and have been getting “quit unexpectedly” message after closing QGIS properly. I click “ignore” but otherwise QGIS is behaving well with the exception of sometimes displaying a map in only a small part of the window which is a known bug and there is a workaround.
But I am only learning QGIS so I am probably asking much less of it than your are.
> On 28 Sep 2018, at 15:41, <b.j.kobben at utwente.nl> <b.j.kobben at utwente.nl> wrote:
> Anyone else has the problem of QGIS 3.2.3 on MacOSX (10.13.6) becoming unstable regularly.?
> It’s worse than plain unstable, it does not want to start at all anymore (MacOS message ”QGIS quit unexpectedly”). The only thing that remedies this is re-installing, or throwing the whole QGIS settings [in Library/Application Support/QGIS/QGIS3] away, which basically comes down to reinstalling, as all settings are gone then.
> yours
> Barend Köbben
> Senior Lecturer – ITC-University of Twente & ATLAS
> PO Box 217, 7500 AE Enschede (Netherlands)
> ITC Building (room 1-065)
> @barendkobben
> +31-(0)53 4874 253
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180928/6131a020/attachment-0001.html>
