[Qgis-user] QGIS 3.2.3 on MacOSX also fails all GDAL
b.j.kobben at utwente.nl
Fri Sep 28 12:10:49 PDT 2018
This solved my problem, thanks.
Barend Köbben
On 28/09/2018, 19:53, "DT" <dmofot at gmail.com<mailto:dmofot at gmail.com>> wrote:
This might be an issue with not having the proper paths in QGIS settings. Have you followed this section from the install readme?
External Program Paths
QGIS 3 does not find external tools needed for Processing. Some configuration options are missing. A workaround is to use QGIS custom variables. Open QGIS Preferences → System.
- Under the Environment section, turn on Use Custom Variables.
- Add (+) a variable
- Select Prepend from the Apply popup
- Enter PATH for the variable
- For the Value enter:
/Library/Frameworks/Python.framework/Versions/3.6/bin:/Library/Frameworks/GDAL.framework/Versions/2.2/Programs:
- Quit QGIS 3 and start it again
On Fri, Sep 28, 2018 at 11:55 AM <b.j.kobben at utwente.nl<mailto:b.j.kobben at utwente.nl>> wrote:
It’s getting worse, now all my GDAL commands down’t waork anymore:
“GDAL command output:
/bin/sh: gdal_merge.py: command not found”
But when I type “gdal_merge.py” in my terminal, it works fine...
Barend Köbben
On 28/09/2018, 16:42, "Qgis-user on behalf of b.j.kobben at utwente.nl<mailto:b.j.kobben at utwente.nl>" <qgis-user-bounces at lists.osgeo.org<mailto:qgis-user-bounces at lists.osgeo.org> on behalf of b.j.kobben at utwente.nl<mailto:b.j.kobben at utwente.nl>> wrote:
Anyone else has the problem of QGIS 3.2.3 on MacOSX (10.13.6) becoming unstable regularly.?
It’s worse than plain unstable, it does not want to start at all anymore (MacOS message ”QGIS quit unexpectedly”). The only thing that remedies this is re-installing, or throwing the whole QGIS settings [in Library/Application Support/QGIS/QGIS3] away, which basically comes down to reinstalling, as all settings are gone then.
yours
Barend Köbben
Senior Lecturer – ITC-University of Twente & ATLAS
PO Box 217, 7500 AE Enschede (Netherlands)
ITC Building (room 1-065)
@barendkobben
+31-(0)53 4874 253
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180928/995f2950/attachment.html>
