[Qgis-user] QGIS 3.2.3 on MacOSX also fails all GDAL
DT
dmofot at gmail.com
Fri Sep 28 10:52:51 PDT 2018
This might be an issue with not having the proper paths in QGIS settings.
Have you followed this section from the install readme?
External Program Paths
QGIS 3 does not find external tools needed for Processing. Some
configuration options are missing. A workaround is to use QGIS custom
variables. Open QGIS Preferences → System.
- Under the *Environment* section, turn on Use Custom Variables.
- Add (+) a variable
- Select Prepend from the *Apply* popup
- Enter PATH for the variable
- For the *Value* enter:
/Library/Frameworks/Python.framework/Versions/3.6/bin:/Library/Frameworks/GDAL.framework/Versions/2.2/Programs:
- Quit QGIS 3 and start it again
On Fri, Sep 28, 2018 at 11:55 AM <b.j.kobben at utwente.nl> wrote:
> It’s getting worse, now all my GDAL commands down’t waork anymore:
> “GDAL command output:
> /bin/sh: gdal_merge.py: command not found”
> But when I type “gdal_merge.py” in my terminal, it works fine...
> Barend Köbben
> On 28/09/2018, 16:42, "Qgis-user on behalf of b.j.kobben at utwente.nl" <
> qgis-user-bounces at lists.osgeo.org on behalf of b.j.kobben at utwente.nl>
> wrote:
> Anyone else has the problem of QGIS 3.2.3 on MacOSX (10.13.6) becoming
> unstable regularly.?
> It’s worse than plain unstable, it does not want to start at all anymore
> (MacOS message ”QGIS quit unexpectedly”). The only thing that remedies this
> is re-installing, or throwing the whole QGIS settings [in
> Library/Application Support/QGIS/QGIS3] away, which basically comes down to
> reinstalling, as all settings are gone then.
> yours
> Barend Köbben
> Senior Lecturer – ITC-University of Twente & ATLAS
> PO Box 217, 7500 AE Enschede (Netherlands)
> ITC Building (room 1-065)
> @barendkobben
> +31-(0)53 4874 253
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180928/e5ffdbe2/attachment.html>
