[Qgis-user] QGIS 3.2.3 on MacOSX also fails all GDAL
b.j.kobben at utwente.nl
Fri Sep 28 08:55:40 PDT 2018
It’s getting worse, now all my GDAL commands down’t waork anymore:
“GDAL command output:
/bin/sh: gdal_merge.py: command not found”
But when I type “gdal_merge.py” in my terminal, it works fine...
Barend Köbben
On 28/09/2018, 16:42, "Qgis-user on behalf of b.j.kobben at utwente.nl<mailto:b.j.kobben at utwente.nl>" <qgis-user-bounces at lists.osgeo.org<mailto:qgis-user-bounces at lists.osgeo.org> on behalf of b.j.kobben at utwente.nl<mailto:b.j.kobben at utwente.nl>> wrote:
Anyone else has the problem of QGIS 3.2.3 on MacOSX (10.13.6) becoming unstable regularly.?
It’s worse than plain unstable, it does not want to start at all anymore (MacOS message ”QGIS quit unexpectedly”). The only thing that remedies this is re-installing, or throwing the whole QGIS settings [in Library/Application Support/QGIS/QGIS3] away, which basically comes down to reinstalling, as all settings are gone then.
yours
Barend Köbben
Senior Lecturer – ITC-University of Twente & ATLAS
PO Box 217, 7500 AE Enschede (Netherlands)
ITC Building (room 1-065)
@barendkobben
+31-(0)53 4874 253
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180928/b294c7d6/attachment.html>
