[Qgis-user] Qgis-user Digest, Vol 158, Issue 11
Gallego Domínguez, David
dgallego at minsait.com
Wed Apr 10 00:19:52 PDT 2019
FYI
-----Mensaje original-----
De: Qgis-user <qgis-user-bounces at lists.osgeo.org> En nombre de qgis-user-request at lists.osgeo.org
Enviado el: martes, 9 de abril de 2019 21:00
Para: qgis-user at lists.osgeo.org
Asunto: Qgis-user Digest, Vol 158, Issue 11
Send Qgis-user mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
https://lists.osgeo.org/mailman/listinfo/qgis-user
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
qgis-user-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific than "Re: Contents of Qgis-user digest..."
Today's Topics:
1. labeling (Boaz Bar Ilan)
2. Re: labeling (Stefan Giese)
3. aktual Distanz to target point (Bernd Laskowski)
4. Qfield WFS-error: features not downloaded/shown (Ville Koivisto)
5. Problem running a lot of GRASS procedures in QGIS 3.6.1 (magerlin)
6. adding to attribute table (Boaz Bar Ilan)
7. Re: adding to attribute table (Christophe Bayle)
Message: 1
Date: Tue, 9 Apr 2019 09:10:55 +0300
To: qgis-user <qgis-user at lists.osgeo.org>
Subject: [Qgis-user] labeling
Message-ID:
<CAP+w7XRJwSD_+B3GBuQt1QOHiMiV=iAxMCfCL51ZOBXaULv3xg at mail.gmail.com>
Content-Type: text/plain; charset="utf-8"
hi
in the label I include 2 fields ( through the expression dialogue )
one appear above the other
is there a way to arrange them in one line?
thanks
boaz
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190409/e914f1d8/attachment-0001.html>
Message: 2
Date: Tue, 9 Apr 2019 08:30:15 +0200
From: Stefan Giese <Stefan.Giese at wheregroup.com>
To: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>, Boaz Bar
Ilan <boazprosie at gmail.com>
Subject: Re: [Qgis-user] labeling
Message-ID: <4a6c0247-05a4-678b-0e99-67b43cc01c6c at wheregroup.com>
Content-Type: text/plain; charset="utf-8"; Format="flowed"
Depends how you connect your fields:
"field1" || ' ' || "field2" -> one line
"field1" || '\n' || "field2" -> two lines
and if you have a '\n' (like in a file path) within your string it would also results in two lines... then you should escape your backslash with \\ or use /
Mit freundlichen Grüßen
Stefan Giese
Projektleiter/Consultant
Aufwind durch Wissen!
Qualifizierte Open-Source-Schulungen
bei derwww.foss-academy.com
WhereGroup GmbH & Co. KG
Schwimmbadstr. 2
79100 Freiburg
Germany
Fon: +49 (0)761 / 519 102 - 61
Fax: +49 (0)761 / 519 102 - 11
stefan.giese at wheregroup.com
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
Am 09.04.2019 um 08:10 schrieb Boaz Bar Ilan:
> hi
> thanks
> boaz
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190409/b87990c5/attachment-0001.html>
Message: 3
Date: Tue, 9 Apr 2019 13:39:12 +0200
From: Bernd Laskowski <bernd.laskowski at reichshof.de>
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] aktual Distanz to target point
Message-ID: <c5fa8011-f45a-9ce8-a669-980cd8c9851f at reichshof.de>
Hi all,
how it's possible to show the actual distance and perhaps the direction from my position(gps) to a marked target/point?
Regards
Bernd
Gemeinde Reichshof
II/10
Bernd Laskowski
Hauptstraße 12
51580 Reichshof
Tel.: (02296) 801 - 313
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190409/7ede8f76/attachment-0001.vcf>
Message: 4
Date: Tue, 9 Apr 2019 18:07:27 +0300
From: "Ville Koivisto" <ville.koivisto at kuntotekniikka.fi>
To: <qgis-user at lists.osgeo.org>
Subject: [Qgis-user] Qfield WFS-error: features not downloaded/shown
Message-ID: <014701d4eee5$f47421c0$dd5c6540$@kuntotekniikka.fi>
Hi list,
Any idea, why Qfield would produce this kind of error with WFS-layers, while in QGIS everything works like it's supposed to? Features are not downloaded, or not at least drawn.
"WFS Layer extent reported by the server is not correct. You may need to zoom again on layer while features are being downloaded"
Qfield 1.0.3
QGIS 3.6
WFS 2.0.0
Best regards,
Ville Koivisto
+35840 701 4283
GIS Expert
Suomen kuntotekniikka Oy
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190409/973a6661/attachment-0001.html>
Message: 5
Date: Tue, 9 Apr 2019 08:44:56 -0700 (MST)
Subject: [Qgis-user] Problem running a lot of GRASS procedures in QGIS
3.6.1
Message-ID: <1554824696657-0.post at n6.nabble.com>
Content-Type: text/plain; charset=us-ascii
Am I the only one having problems running Grass 7 from QGIS 3.6.1?
For instance trying to run v.net.salesman in this project Travelling_Salesman.zip <http://osgeo-org.1560.x6.nabble.com/file/t202356/Travelling_Salesman.zip>
gives this error:
WARNING: Table <vector_5cacbc240a38d3> does not exist in database <$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db>
Are anybody else able to make it run?
Complete error message is here:
Regards Morten
Currently using Qgis 2.18.23 (OSGeo4) and Qgis 3.4.2 in parallel Windows 7, 64bit
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
Message: 6
Date: Tue, 9 Apr 2019 19:39:45 +0300
Subject: [Qgis-user] adding to attribute table
Message-ID:
<CAP+w7XQ26-OeFncD0isYmUZkcdrBN6NpORTSyAPO98UDd51z6g at mail.gmail.com>
hi
using 3.4.6
I have an attribute table to which I want to add new fields with their values all from excel spreadsheet is there a way ?
thanks
boaz
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190409/06a6d238/attachment-0001.html>
Message: 7
Date: Tue, 9 Apr 2019 19:17:38 +0200
To: Boaz Bar Ilan <boazprosie at gmail.com>
Cc: qgis-user <qgis-user at lists.osgeo.org>
Subject: Re: [Qgis-user] adding to attribute table
Message-ID:
<CALtyEsmxmAb1LVxjXsOKFomDsgDn1+e03WyTsz23R7=gWp0GSg at mail.gmail.com>
You should find tons of doc or tutorials if you search for 'join attribute table qgis' :)
Here is an example:
https://www.gislounge.com/working-with-tables-mastering-qgis/
Crucial point is: do you have a common field between the two sheets to find the lines that match.
Le mar. 9 avr. 2019 à 18:40, Boaz Bar Ilan <boazprosie at gmail.com> a écrit :
> hi
> using 3.4.6
> thanks
> boaz
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190409/a2e54bdf/attachment-0001.html>
Subject: Digest Footer
End of Qgis-user Digest, Vol 158, Issue 11
Este correo electrónico y, en su caso, cualquier fichero anexo al mismo, contiene información de carácter confidencial exclusivamente dirigida a su destinatario o destinatarios. Si no es vd. el destinatario indicado, queda notificado que la lectura, utilización, divulgación y/o copia sin autorización está prohibida en virtud de la legislación vigente. En el caso de haber recibido este correo electrónico por error, se ruega notificar inmediatamente esta circunstancia mediante reenvío a la dirección electrónica del remitente.
Evite imprimir este mensaje si no es estrictamente necesario.
This email and any file attached to it (when applicable) contain(s) confidential information that is exclusively addressed to its recipient(s). If you are not the indicated recipient, you are informed that reading, using, disseminating and/or copying it without authorisation is forbidden in accordance with the legislation in effect. If you have received this email by mistake, please immediately notify the sender of the situation by resending it to their email address.
Avoid printing this message if it is not absolutely necessary.
