[Qgis-user] Raster analysis , Proximity (raster distance)
Dimitris sal
jimmaras123 at gmail.com
Thu Aug 1 05:32:25 PDT 2019
I tried to change the CRS to a meter one , i create a new distance analysis
with it and when i try to convert it back to EPSG 4326 the data in the
raster was destroyed.
Richard my image is at 700x700 at specific coordinates in degrees. Is there
any tool i can use to convert the data from my raster from degrees to
meters?
Στις Πέμ, 1 Αυγ 2019 στις 2:41 μ.μ., ο/η Richard McDonnell <
richard.mcdonnell at opw.ie> έγραψε:
> Hi Dimitris,
> Welcome!!
> To answer your question, use the Georeferenced coordinates and run, the
> distances will be based on the resolution of your image, so 5m resolution
> will result in a proximity raster of 5m intervals.
> You might want to set the Maximum distance, as this will help to minimise
> processing and Image size.
> Reagrds,
> Richard.
> *From:* Qgis-user <qgis-user-bounces at lists.osgeo.org> *On Behalf Of *Dimitris
> sal
> *Sent:* 01 August 2019 12:13
> *To:* qgis-user at lists.osgeo.org
> *Subject:* [Qgis-user] Raster analysis , Proximity (raster distance)
> Hello to all ,
> This is my first message here. I am trying to create a proximity map with
> the Raster analysis tool. My problem is that I only get two options for
> distance units , pixels coordinates and georeferenced coordinates while I
> want to get them in meters.
> I also used the grass tool , r.grow.distance that provides in advanced
> parameters the option "Output distances in meters instead of map units" If
> i check this option i get the following error ERROR: Raster map or group
> not found.
> Does any of you know any workaround for this?
> I am using QGiS 3.8.1 with GRASS 7.6.1
> Kind regards
> Dimitris
> Email Disclaimer: http://www.opw.ie/en/disclaimer/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190801/685d75ec/attachment.html>
