[Qgis-user] Raster analysis , Proximity (raster distance)
Richard McDonnell
richard.mcdonnell at opw.ie
Thu Aug 1 04:41:17 PDT 2019
Hi Dimitris,
Welcome!!
To answer your question, use the Georeferenced coordinates and run, the distances will be based on the resolution of your image, so 5m resolution will result in a proximity raster of 5m intervals.
You might want to set the Maximum distance, as this will help to minimise processing and Image size.
Reagrds,
Richard.
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of Dimitris sal
Sent: 01 August 2019 12:13
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] Raster analysis , Proximity (raster distance)
Hello to all ,
This is my first message here. I am trying to create a proximity map with the Raster analysis tool. My problem is that I only get two options for distance units , pixels coordinates and georeferenced coordinates while I want to get them in meters.
I also used the grass tool , r.grow.distance that provides in advanced parameters the option "Output distances in meters instead of map units" If i check this option i get the following error ERROR: Raster map or group not found.
Does any of you know any workaround for this?
I am using QGiS 3.8.1 with GRASS 7.6.1
Kind regards
Dimitris
Email Disclaimer: http://www.opw.ie/en/disclaimer/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190801/23a17cef/attachment.html>
