[Qgis-user] Raster analysis , Proximity (raster distance)
Raymond Nijssen
r.nijssen at terglobo.nl
Thu Aug 1 04:39:06 PDT 2019
Hi Dimitris,
You could convert your raster data into a projection that uses meters.
> Layer > Save as...
Raymond
On 01-08-19 13:12, Dimitris sal wrote:
> Hello to all ,
> This is my first message here. I am trying to create a proximity map
> with the Raster analysis tool. My problem is that I only get two options
> for distance units , pixels coordinates and georeferenced coordinates
> while I want to get them in meters.
> I also used the grass tool , r.grow.distance that provides in advanced
> parameters the option "Output distances in meters instead of map units"
> If i check this option i get the following error ERROR: Raster map or
> group not found.
> Does any of you know any workaround for this?
> I am using QGiS 3.8.1 with GRASS 7.6.1
> Kind regards
> Dimitris
> Qgis-user mailing list
