[Qgis-user] Smoothing polygons
Carolina Boccato
cboccato at gmail.com
Thu Aug 1 08:35:51 PDT 2019
Hi Christoph,
Yes, there is this implementation!
In the processing toolbox at the Grass provider you will find v.generalize.
This one has several algorithms, one of them is chaikins.
Sincerely,
Carolina
On Thu, 1 Aug 2019 at 10:18, Stefan Giese <Stefan.Giese at wheregroup.com>
wrote:
> Hi Christoph,
> under processing tools you will find 2 vector smooth tools, one is native
> QGIS, the other comes from SAGA (
> http://www.saga-gis.org/saga_tool_doc/2.2.2/shapes_lines_7.html). Just
> type "smooth" into the filter of the processing tools.
> Mit freundlichen Grüßen
> Stefan Giese
> Projektleiter/Consultant
> Kompaktkurs Aufbau einer GDI mit Open-Source-Software
> FOSS Academy Sommerschule: 23. bis 27.09.2019https://www.foss-academy.com/kompaktkurse.html
> WhereGroup GmbH
> Eifelstraße 7
> 53119 Bonn
> Germany
> Fon: +49 (0)228 / 90 90 38 - 61
> Fax: +49 (0)228 / 90 90 38 - 11
> stefan.giese at wheregroup.comwww.wheregroup.com
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
> Am 01.08.2019 um 15:09 schrieb Christoph Jung:
> Hello everybody,
> Does QGIS has a similar smoothing function like ArcGIS described in the
> following webpage?
> https://desktop.arcgis.com/de/arcmap/10.3/tools/cartography-toolbox/smooth-polygon.htm
> I think I saw something like the result of the PAEK algorithm in QGIS, but
> I cannot remember when and where ^^
> Does an implementation of the chaikins algorithm exists in any tool, that
> can be integrated into the toolbox?
> I tried out the Smooth processing directly in QGIS and the plugin
> cartographic line generalisation. But both are too close orientated on the
> original geometry for me. I am searching for the possibility to create a
> more abstract copy of a polygon. Maybe somebody has some ideas about it.
> Sincerely,
> Christoph
> Qgis-user mailing listQgis-user at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190801/e525d3eb/attachment.html>
