[Qgis-user] Smoothing polygons
Christoph Jung jagodki.cj at gmail.com
Thu Aug 1 11:58:14 PDT 2019
What a shame, I totally ignored the grass tools ^^’
Thanks at all for your fast responses. I will try it out during the next days.
Christoph
> Am 01.08.2019 um 17:35 schrieb Carolina Boccato <cboccato at gmail.com>:
> Hi Christoph,
> Yes, there is this implementation!
> In the processing toolbox at the Grass provider you will find v.generalize. This one has several algorithms, one of them is chaikins.
> Sincerely,
> Carolina
>> On Thu, 1 Aug 2019 at 10:18, Stefan Giese <Stefan.Giese at wheregroup.com> wrote:
>> Hi Christoph,
>> under processing tools you will find 2 vector smooth tools, one is native QGIS, the other comes from SAGA (http://www.saga-gis.org/saga_tool_doc/2.2.2/shapes_lines_7.html). Just type "smooth" into the filter of the processing tools.
>> Mit freundlichen Grüßen
>> Stefan Giese
>> Projektleiter/Consultant
>> Kompaktkurs Aufbau einer GDI mit Open-Source-Software
>> FOSS Academy Sommerschule: 23. bis 27.09.2019
>> https://www.foss-academy.com/kompaktkurse.html
>> WhereGroup GmbH
>> Eifelstraße 7
>> 53119 Bonn
>> Germany
>> Fon: +49 (0)228 / 90 90 38 - 61
>> Fax: +49 (0)228 / 90 90 38 - 11
>> stefan.giese at wheregroup.com
>> www.wheregroup.com
>> Geschäftsführer:
>> Olaf Knopp, Peter Stamm
>> Amtsgericht Bonn, HRB 9885
>>> Am 01.08.2019 um 15:09 schrieb Christoph Jung:
>>> Hello everybody,
>>> Does QGIS has a similar smoothing function like ArcGIS described in the following webpage?
>>> https://desktop.arcgis.com/de/arcmap/10.3/tools/cartography-toolbox/smooth-polygon.htm
>>> I think I saw something like the result of the PAEK algorithm in QGIS, but I cannot remember when and where ^^
>>> Does an implementation of the chaikins algorithm exists in any tool, that can be integrated into the toolbox?
>>> I tried out the Smooth processing directly in QGIS and the plugin cartographic line generalisation. But both are too close orientated on the original geometry for me. I am searching for the possibility to create a more abstract copy of a polygon. Maybe somebody has some ideas about it.
>>> Sincerely,
>>> Christoph
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190801/51af5133/attachment.html>
