[Qgis-user] failed to add WMS layer
Richard Duivenvoorde
rdmailings at duif.net
Fri Aug 2 01:57:28 PDT 2019
On 01/08/2019 21.35, Andrea Peri wrote:
> Have you the cache to zero size?
> I discovered this kind of strangenissue some weeks ago
> If the qgis cache size is turn to zero the capabilities fail when go to
> add the map to the Canvas.
> This issue is on only with some wms (mapserver, geoserver) do not with
> qgisserver.
> I dont know with arcgis rest services.
Hi Andrea,
Can you provide a situation I can reproduce (OS, QGS version, service,
how you load the caps etc) ? Because this would be a proper issue!
But I cannot reproduce it with 3.4, 3.8 or master that I have running
here on Debian.
So if you have a good reproducable case, it sounds like it should be fixed.
Thanks,
