[Qgis-user] failed to add WMS layer
Andrea Peri
aperi2007 at gmail.com
Fri Aug 2 03:26:47 PDT 2019
Are trying to Connect to qgis server?
I see the qgis dont have any issues to connect to qgis server.
Instead trying to connect to a wms mapserver or to a wms geoserver.
I see the issue.
To reply
Cache setting size yo zero in
Qgis and try to add a map wms to canvas from a mapserver or geoserver
Please note that
The issue is when click on add to canvas not when connect to retrieve the
list of layers.
I have this issue on qgis 3.8.0 for windows 64 bit.
A.
Il ven 2 ago 2019, 10:57 Richard Duivenvoorde <rdmailings at duif.net> ha
scritto:
> On 01/08/2019 21.35, Andrea Peri wrote:
> > Have you the cache to zero size?
> > I discovered this kind of strangenissue some weeks ago
> > If the qgis cache size is turn to zero the capabilities fail when go to
> > add the map to the Canvas.
> > This issue is on only with some wms (mapserver, geoserver) do not with
> > qgisserver.
> > I dont know with arcgis rest services.
> Hi Andrea,
> Can you provide a situation I can reproduce (OS, QGS version, service,
> how you load the caps etc) ? Because this would be a proper issue!
> But I cannot reproduce it with 3.4, 3.8 or master that I have running
> here on Debian.
> So if you have a good reproducable case, it sounds like it should be fixed.
> Thanks,
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190802/5cd4873e/attachment.html>
