[Qgis-user] failed to add WMS layer
Andrea Peri
aperi2007 at gmail.com
Fri Aug 2 05:30:58 PDT 2019
I know the network plugin. It help me to understand this bug.
The bug is due to the wms provider that when you click on "add to map"
button try to read from the cache the capability info.
If te cache is to zero , in old qgis 2.18 the wms provider do another
request getcapabilities to the wms server to have it.
Instead in the qgis 3, if the cache if to zero, the request is not saved
and the read for add to map fail.
I notice this happen with mapserver and geosevrver, instead with
qgis-server don'.
The only explanation I can do is that for qgis-server it used a differente
code for provider wms.
A.
Il giorno ven 2 ago 2019 alle ore 13:31 Richard Duivenvoorde <
rdmailings at duif.net> ha scritto:
> On 02/08/2019 12.26, Andrea Peri wrote:
> > Are trying to Connect to qgis server?
> > I see the qgis dont have any issues to connect to qgis server.
> > Instead trying to connect to a wms mapserver or to a wms geoserver.
> > I see the issue.
> > To reply
> > Cache setting size yo zero in
> > Qgis and try to add a map wms to canvas from a mapserver or geoserver
> > Please note that
> > The issue is when click on add to canvas not when connect to retrieve
> > the list of layers.
> So it is not the capabilities request that is failing?
> I just tried to reproduce this both on Linux and Windows, setting the
> cache to 0 and connect to a geoserver instance, and all goes well.
> Both capabilities and getmap requests.
> Can you maybe install the 'QGIS Network Logger' plugin? And see what
> requests QGIS is firing to the server?
> And maybe try to replay those requests in a browsers?
> Others can reproduce this?
> Regards,
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190802/2712a506/attachment.html>
