[Qgis-user] Adding topological vertices
Jan Hartmann j.l.h.hartmann at uva.nl
Fri Aug 23 06:37:27 PDT 2019
Hi Bernard, I downloaded QGIS 3.8.2, and now everything works perfectly.
Not sure if I got it right in 3.8.1  Thanks!
Jan
On 8/14/2019 1:44 PM, Bernhard Ströbl wrote:
> Hi Jan,
> sorry I cannot reproduce the behaviour you describe in QGIS 3.4.10. Be
> sure to read about the new vertex tool (and its changed behaviour
> compared to 2.*) in the manual [1]
> Bernhard
> [1]
> https://docs.qgis.org/3.4/en/docs/user_manual/working_with_vector/editing_geometry_attributes.html#vertex-tool
> Am 09.08.2019 um 14:35 schrieb Jan Hartmann:
>> Hi all,
>> In QGIS 2 I could add a vertex on a segment shared by two polygons
>> just by double-clicking on that segment. When topological editing was
>> enabled, a new vertex was added to both polygons, and I could move
>> them both just by dragging.
>> In QGIS 3, when topological editing is enabled, moving a shared
>> vertex is a bit more complex. I cannot just click on that vertex and
>> then click on the destination location, for then only one of the
>> shared vertices is moved. I have to shift-drag around the vertex,
>> then click on the selected vertices, and only then all shared
>> vertices are moved. No problem with that, by the way.
>> The real problem is when I want to add a vertex on a shared segment.
>> When I double-click on that segment, a new vertex appears, but only
>> on one of the segments. I can move that vertex, but only one segment
>> is moved. The underlying segments remain in place. To move them too,
>> I have to create vertices on all of them, and move them all to the
>> new location. This *is* a problem.
>> Is there a solution for this? Do I overlook something?
>> Regards,
>> Jan Hartmann
>> Amsterdam
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> __________ Information from ESET Mail Security, version of virus
> signature database 19852 (20190814) __________
> The message was checked by ESET Mail Security.
> http://www.eset.com
