[Qgis-user] Adding topological vertices
Bernhard Ströbl
bernhard.stroebl at jena.de
Wed Aug 14 04:44:03 PDT 2019
Hi Jan,
sorry I cannot reproduce the behaviour you describe in QGIS 3.4.10. Be
sure to read about the new vertex tool (and its changed behaviour
compared to 2.*) in the manual [1]
Bernhard
[1]
https://docs.qgis.org/3.4/en/docs/user_manual/working_with_vector/editing_geometry_attributes.html#vertex-tool
Am 09.08.2019 um 14:35 schrieb Jan Hartmann:
> Hi all,
> In QGIS 2 I could add a vertex on a segment shared by two polygons just
> by double-clicking on that segment. When topological editing was
> enabled, a new vertex was added to both polygons, and I could move them
> both just by dragging.
> In QGIS 3, when topological editing is enabled, moving a shared vertex
> is a bit more complex. I cannot just click on that vertex and then click
> on the destination location, for then only one of the shared vertices is
> moved. I have to shift-drag around the vertex, then click on the
> selected vertices, and only then all shared vertices are moved. No
> problem with that, by the way.
> The real problem is when I want to add a vertex on a shared segment.
> When I double-click on that segment, a new vertex appears, but only on
> one of the segments. I can move that vertex, but only one segment is
> moved. The underlying segments remain in place. To move them too, I have
> to create vertices on all of them, and move them all to the new
> location. This *is* a problem.
> Is there a solution for this? Do I overlook something?
> Regards,
> Jan Hartmann
> Amsterdam
> Qgis-user mailing list
__________ Information from ESET Mail Security, version of virus signature database 19852 (20190814) __________
The message was checked by ESET Mail Security.
http://www.eset.com
