[Qgis-user] Distance matrix using shortest path (FH longest path and others)
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Mon Aug 26 11:14:12 PDT 2019
Shortest path analysis can be done by counting the number of nodes (connections or intersections) or by using a distance variable (traditionally length). However, “length” can be anything. It can be any combination of factors. Therefore, if you can model the various factors in a single “length” variable, then you can find the best path for your model. Some algorithm will give you all paths to one point, some only the shortest path, and some will permit you to use a maximum cut off (ie max radiation absorption dose if radiation is part of the model.)
Nicolas
> Le 26 août 2019 à 13:43, Falk Huettmann <fhuettmann at alaska.edu> a écrit :
> Dear Kind Colleagues,
> thanks, I have a similar question, but with an opposite aim:
> We have two points,
> and want to connect them,
> but then, NOT with the most direct and shortest path.
> Rather, with the most meaningful and considerate one.
> Like,
> length is not to be penalized but other factors, habitats available, amount of pixels
> underneath etc.
> Perhaps even showing different scenarios (aka, many paths lead to Rome...) ?
> The path can consist of more than a line, an area connection let's say.
> So in other words: the optimization is NOT done by short distance.
> Would you have any ideas and suggestions on that ?
> Thanks so much for any input
> Falk Huettmann
>> On Mon, Aug 26, 2019 at 2:07 AM Chintan Advani <chintanadvani at gmail.com> wrote:
>> Hi guys,
>> I have a shape file with set of points on a road network. I am trying to find the shortest distance among these points using the shortest path tool. I have tried using the distance matrix tool in QGIS but it gives eucledian distance between these points whereas I am looking the path distance (based on road network). Can someone please suggest some tool or technique that can help me solve this problem?
>> Thanks and Regards,
>> __________________________________________
>> Advani Chintan Sanjeev
>> Research Scholar,
>> Civil Engineering and Build Environment,
>> Queensland University of Technology,
>> Brisbane-4000, Australia.
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190826/6d94739c/attachment.html>
