[Qgis-user] Distance matrix using shortest path
Chintan Advani
chintanadvani at gmail.com
Tue Aug 27 19:25:16 PDT 2019
The QNEAT3 tool for 'OD Matrix from Points as Table' works perfectly well
for the problem. However, the API has limited access to points. I have a
set of 1400 points, whereas the API allows only 50 points for matrix
development. Is it possible to increase the access points?
Thanks and Regards,
Advani Chintan Sanjeev
Research Scholar,
Civil Engineering and Build Environment,
Queensland University of Technology,
Brisbane-4000, Australia.
On Tue, Aug 27, 2019 at 12:47 AM Clemens Raffler <clemens.raffler at gmail.com>
wrote:
> Hi,
> you could try the plugin QNEAT3 which supports network based
> origin-destination matrices between points of one layer or multiple sets
> of points in two layers out of the box. The plugin is available through
> the QGIS plugin repository and gets loaded in the processing toolbox,
> the algorithms you are looking for are called 'OD Matrix from Points as
> Table' or 'OD Matrix from Layers as Table'. The distance that is output
> to the matrix is measured based on the provided network layer.
> For more info on the plugin you can checkout https://root676.github.io/
> I hope this helps!
> Best, Clemens
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190828/f69381de/attachment.html>
