[Qgis-user] Distance matrix using shortest path
Clemens Raffler clemens.raffler at gmail.com
Wed Aug 28 00:15:13 PDT 2019
can you send me the error message that informs you about the limit? I
was just wondering because I did not add any restriction on the number
of input points in QNEAT3, neither in the n:n, nor in the m:n
algorithms. I have also performed analyses with more than 5000 points
per dataset (of course this analyses take much more time because of the
higher workload).
Best,
Clemens
On 28.08.19 04:25, Chintan Advani wrote:
> Hi,
> The QNEAT3 tool for 'OD Matrix from Points as Table' works perfectly
> well for the problem. However, the API has limited access to points. I
> have a set of 1400 points, whereas the API allows only 50 points for
> matrix development. Is it possible to increase the access points?
> Thanks and Regards,
> __________________________________________
> Advani Chintan Sanjeev
> Research Scholar,
>         Civil Engineering and Build Environment,
> Queensland University of Technology,
> Brisbane-4000, Australia.
> On Tue, Aug 27, 2019 at 12:47 AM Clemens Raffler
> <clemens.raffler at gmail.com <mailto:clemens.raffler at gmail.com>> wrote:
>     Hi,
>     you could try the plugin QNEAT3 which supports network based
>     origin-destination matrices between points of one layer or
>     multiple sets
>     of points in two layers out of the box. The plugin is available
>     through
>     the QGIS plugin repository and gets loaded in the processing toolbox,
>     the algorithms you are looking for are called 'OD Matrix from
>     Points as
>     Table' or 'OD Matrix from Layers as Table'. The distance that is
>     output
>     to the matrix is measured based on the provided network layer.
>     For more info on the plugin you can checkout
>     https://root676.github.io/
>     I hope this helps!
>     Best, Clemens
>     _______________________________________________
>     Qgis-user mailing list
>     Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190828/9bdbc039/attachment.html>
