[Qgis-user] Data defined assistant apparently does not work with buffer tool
    Nyall Dawson
    nyall.dawson at gmail.com
    Thu Dec  5 15:22:15 PST 2019
On Wed, 4 Dec 2019 at 21:39, Hernán De Angelis <dhdeangelis at comhem.se> wrote:
> Hi QGIS'ers
> I am experiencing a problem while trying to generate vector buffers using functions or fields using the "assistant".
> The buffer tool works as expected for fixed buffer widths and when using the expression editor but seemingly does not work (or produces weird scaling problems) for data defined buffers if I use the "assistant".
> I see in GitHub this has been reported for the symbology editor but it seems that it also affects the buffer tool. I am using QGIS 3.10.0.
Which bug report is this?
Nyall
> Has anyone also experienced this?
> Hernán
> Qgis-user mailing list
