[Qgis-user] problems running saga tools in QGIS 3.4.13
Jonathan Aguero jaguero.ucr at gmail.com
Sat Dec 7 14:00:59 PST 2019
Hi list,
I am trying to run the IDW interpolation using the SAGA tool inside QGIS. I
installed the pre-packaged version for win10 with qgis 3.4.13 and SAGA
2.3.2. I got the following messages:
Loading resulting layers
The following layers were not correctly
generated.<ul><li>C:/Users/Jonathan/AppData/Local/Temp/processing_99d6ec7b49d940d5981d865b31db13c7/aa2d1cef96c54efe8fc9201957fa5d8b/TARGET_OUT_GRID.sdat</li></ul>You
can check the 'Log Messages Panel' in QGIS main window to find more
information about the execution of the algorithm.
 C:\Users\Jonathan\Documents>call saga_cmd grid_gridding "Inverse Distance
Weighted" -SHAPES "C:/Users/Jonathan/Documents/San Ramón/centroides1.shp"
-FIELD "_range" -DW_WEIGHTING 1 -DW_IDW_POWER 2.0 -DW_IDW_OFFSET false
-DW_BANDWIDTH 1.0 -SEARCH_RANGE 0 -SEARCH_RADIUS 1000.0 -SEARCH_POINTS_ALL
0 -SEARCH_POINTS_MIN -1 -SEARCH_POINTS_MAX 20 -SEARCH_DIRECTION 0
-TARGET_USER_SIZE 25.0 -TARGET_DEFINITION 0 -TARGET_USER_FITS 0
-TARGET_OUT_GRID
"C:/Users/Jonathan/AppData/Local/Temp/processing_99d6ec7b49d940d5981d865b31db13c7/aa2d1cef96c54efe8fc9201957fa5d8b/TARGET_OUT_GRID.sdat"
Can someone help me find out the problem here?
Regards
Jo
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191207/8c2ba9db/attachment.html>
