[Qgis-user] problems running saga tools in QGIS 3.4.13
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Sat Dec 7 19:30:45 PST 2019
The easiest way is just to use Saga directly. Possible problem is that you have a space and accent in the path. « San Ramón ».  You could try removing those.
Nicolas
> Le 7 déc. 2019 à 17:01, Jonathan Aguero <jaguero.ucr at gmail.com> a écrit :
> Hi list,
> I am trying to run the IDW interpolation using the SAGA tool inside QGIS. I installed the pre-packaged version for win10 with qgis 3.4.13 and SAGA 2.3.2. I got the following messages:
> Loading resulting layers
> The following layers were not correctly generated.<ul><li>C:/Users/Jonathan/AppData/Local/Temp/processing_99d6ec7b49d940d5981d865b31db13c7/aa2d1cef96c54efe8fc9201957fa5d8b/TARGET_OUT_GRID.sdat</li></ul>You can check the 'Log Messages Panel' in QGIS main window to find more information about the execution of the algorithm.
>  C:\Users\Jonathan\Documents>call saga_cmd grid_gridding "Inverse Distance Weighted" -SHAPES "C:/Users/Jonathan/Documents/San Ramón/centroides1.shp" -FIELD "_range" -DW_WEIGHTING 1 -DW_IDW_POWER 2.0 -DW_IDW_OFFSET false -DW_BANDWIDTH 1.0 -SEARCH_RANGE 0 -SEARCH_RADIUS 1000.0 -SEARCH_POINTS_ALL 0 -SEARCH_POINTS_MIN -1 -SEARCH_POINTS_MAX 20 -SEARCH_DIRECTION 0 -TARGET_USER_SIZE 25.0 -TARGET_DEFINITION 0 -TARGET_USER_FITS 0 -TARGET_OUT_GRID "C:/Users/Jonathan/AppData/Local/Temp/processing_99d6ec7b49d940d5981d865b31db13c7/aa2d1cef96c54efe8fc9201957fa5d8b/TARGET_OUT_GRID.sdat"
> Can someone help me find out the problem here?
> Regards
> Jo
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191207/1720b6c1/attachment.html>
