[Qgis-user] Imported Line Symbol Problem
    Andreas Neumann
    a.neumann at carto.net
    Mon Dec 16 23:28:45 PST 2019
Hi Dave,
You would create a folder anywhere in your file system (preferably not
on a slow partition), copy the necessary SVG files in there and then
create a configuration in "Settings" --> "Options" --> "SVG paths" -->
"add a new entry (green plus)" with a path to the folder you created in
the previous step.
With news configurations, SVG symbols can also be embedded into the
project or qml style file or it could point to a central URL somewhere
on the web.
Hope this helps,
Andreas
On 2019-12-17 03:27, Dave Gardiner wrote:
> Hi Jorge
> Here is an extract form one of the source xls files. Embedded in here is a
> reference to a svg symbol, in this case "geology/arrows_sinistral.svg". I
> have located this file along with other associated svg files but where is
> QGIS expecting to see these files. What is the root directory for
> geology/arrows_sinistral.svg.
> Regards
> Dave
> </layer>
> -<layer locked="0" class="MarkerLine" pass="0">
> <prop v="12.75" k="interval"/>
> <prop v="0,0" k="interval_map_unit_scale"/>
> <prop v="MM" k="interval_unit"/>
> <prop v="0" k="offset"/>
> <prop v="10.75" k="offset_along_line"/>
> <prop v="0,0" k="offset_along_line_map_unit_scale"/>
> <prop v="MM" k="offset_along_line_unit"/>
> <prop v="0,0" k="offset_map_unit_scale"/>
> <prop v="MM" k="offset_unit"/>
> <prop v="interval" k="placement"/>
> <prop v="1" k="rotate"/>
> -<symbol name="@fault2611 at 1" type="marker" alpha="1">
> -<layer locked="0" class="SvgMarker" pass="0">
> <prop v="0" k="angle"/>
> <prop v="#000000" k="color"/>
> <prop v="1" k="horizontal_anchor_point"/>
> <prop v="geology/arrows_sinistral.svg" k="name"/>
> <prop v="0,0" k="offset"/>
> <prop v="#000000" k="outline_color"/>
> <prop v="1" k="outline_width"/>
> <prop v="0,0" k="outline_width_map_unit_scale"/>
> <prop v="MM" k="outline_width_unit"/>
> <prop v="area" k="scale_method"/>
> <prop v="5.25" k="size"/>
> <prop v="0,0" k="size_map_unit_scale"/>
> <prop v="MM" k="size_unit"/>
> <prop v="1" k="vertical_anchor_point"/>
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191217/bb8bf3d6/attachment-0001.html>
