[Qgis-user] Editing Oracle table - can't add feature
Maria Grazia Cuzzani mariagrazia.cuzzani at cittametropolitana.bo.it
Tue Dec 17 01:29:13 PST 2019
Hi Jeremie
we found this about 3D data in Oracle and QGis:
https://gis.stackexchange.com/questions/251768/only-last-line-of-oracle-spatial-multiline-is-drawn-in-qgis
We had geometries with Z and M that gave problems (GType 4401,4402,4406), we have re-imported the data in 2D and now we see them well.
About PK issue we are studying..
We found that Primary Key CONSTRAINT_NAME maybe must be egual to the INDEX_NAME to work well (otherwise Attribute table was filtered)..
We found this about 64 bit version https://issues.qgis.org/issues/9971
SRID
Did you verify SRID of each single shape?
select  a.shape.sdo_srid from mylayer a
Since you're using oracle I take this opportunity...
you had to give the grant of SELECT to all the users in the spatial index tables MDRT* to use spatial indexes?
mg
Città metropolitana di Bologna
Settore strutture tecnologiche, comunicazione e servizi strumentali
U.O. Servizi alle Unioni e ai Comuni - ufficio SIT
Via Benedetto XIV, 3 - 40126 Bologna
Tel 051 6598881 - Fax 051 6599025
mailto:mariagrazia.cuzzani at cittametropolitana.bo.it
http://cartografia.cittametropolitana.bo.it
----- Messaggio originale -----
Da: "p.jeremie" <p.jeremie at gmail.com>
A: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
Inviato: Venerdì, 13 dicembre 2019 15:09:15
Oggetto: Re: [Qgis-user] Editing Oracle table - can't add feature
Hello,
I found that if the table contains geometry in 3D with SRID 2154, QGIS can't
add the geometry in the table.
If the geometry is 2D, it's ok.
Still, I don't understand why I don't have the PRIMARY KEY column not filled
whereas it is defined in the database...
And why QGIS tells me that the SRID is not defined whereas it is defined in
the MDSYS.USER_SDO_GEOM_METADATA view.
Any idea ?
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
Qgis-user mailing list
Qgis-user at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Ai sensi del Dlgs. 196/2003 - Codice in materia di tutela dei dati personali - si informa che il presente messaggio di posta elettronica e gli eventuali suoi allegati, relativamente ai dati personali contenuti, sono riservati ai destinatari.
Questi potranno inoltrare il messaggio esclusivamente per finalita' istituzionali e/o dipendenti da ragioni di servizio del mittente e/o del destinatario.
Non e' consentita, salvo espressa autorizzazione del mittente, qualunque forma di divulgazione del messaggio.
Qualora il presente messaggio fosse ricevuto per errore, si chiede gentilmente di procedere alla sua cancellazione.
Si rende noto che la risposta alla presente e-mail potrebbe essere visualizzata, per ragioni di servizio, da personale e collaboratori della Citta' metropolitana di Bologna diversi dal titolare della casella di posta elettronica.
L'indirizzo e gli altri dati personali del mittente non possono essere utilizzati se non per ragioni istituzionali e/o di servizio.
