[Qgis-user] symbolize points by their size and category
Raymond Nijssen
r.nijssen at terglobo.nl
Fri Feb 1 02:59:21 PST 2019
Hi Alejandro,
You could do the color by a "categorized" symbol (as usual) and the size
based on a "data driven override" with an expression calculating your
attribute values to symbol sizes.
Good luck,
Raymond
On 01-02-19 11:50, Alejandro Chamizo de Castro wrote:
> Hello colleagues,
> do you know if it is possible to symbolize in QGIS 3.x a layer of points
> according to its size and its category?
> For example. size according to number and colors based on its category.
> Thank you
> +34 653681823
> www.gisland.es <http://www.gisland.es>
> Mailtrack
> <https://mailtrack.io?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality5&>
> Remitente notificado con
> Mailtrack
> 01/02/19 11:50:24
> Qgis-user mailing list
