[Qgis-user] symbolize points by their size and category
DelazJ delazj at gmail.com
Fri Feb 1 03:03:59 PST 2019
See
https://docs.qgis.org/testing/en/docs/user_manual/working_with_vector/vector_properties.html#proportional-symbol-and-multivariate-analysis
Regards,
Harrissou
Le ven. 1 févr. 2019 à 11:59, Raymond Nijssen <r.nijssen at terglobo.nl> a
écrit :
> Hi Alejandro,
> You could do the color by a "categorized" symbol (as usual) and the size
> based on a "data driven override" with an expression calculating your
> attribute values to symbol sizes.
> Good luck,
> Raymond
> On 01-02-19 11:50, Alejandro Chamizo de Castro wrote:
> > Hello colleagues,
> > do you know if it is possible to symbolize in QGIS 3.x a layer of points
> > according to its size and its category?
> > For example. size according to number and colors based on its category.
> > Thank you
> > +34 653681823
> > www.gisland.es <http://www.gisland.es>
> > Mailtrack
> https://mailtrack.io?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality5&>
> >       Remitente notificado con
> > Mailtrack
> > 01/02/19 11:50:24
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190201/06aba10b/attachment.html>
