[Qgis-user] symbolize points by their size and category
Alejandro Chamizo de Castro
alechamizo at gmail.com
Mon Feb 11 23:36:58 PST 2019
Thank you very much for your sopport.
Regards
[image: Mailtrack]
<https://mailtrack.io?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality5&>
Remitente
notificado con
Mailtrack
12/02/19
8:36:32
El vie., 1 feb. 2019 a las 12:04, DelazJ (<delazj at gmail.com>) escribió:
> Hi,
> See
> https://docs.qgis.org/testing/en/docs/user_manual/working_with_vector/vector_properties.html#proportional-symbol-and-multivariate-analysis
> Regards,
> Harrissou
> Le ven. 1 févr. 2019 à 11:59, Raymond Nijssen <r.nijssen at terglobo.nl> a
> écrit :
>> Hi Alejandro,
>> You could do the color by a "categorized" symbol (as usual) and the size
>> based on a "data driven override" with an expression calculating your
>> attribute values to symbol sizes.
>> Good luck,
>> Raymond
>> On 01-02-19 11:50, Alejandro Chamizo de Castro wrote:
>> > Hello colleagues,
>> > do you know if it is possible to symbolize in QGIS 3.x a layer of
>> points
>> > according to its size and its category?
>> > For example. size according to number and colors based on its category.
>> > Thank you
>> > +34 653681823
>> > www.gisland.es <http://www.gisland.es>
>> > Mailtrack
>> > Remitente notificado con
>> > Mailtrack
>> > 01/02/19 11:50:24
>> > _______________________________________________
>> > Qgis-user mailing list
>> > Qgis-user at lists.osgeo.org
>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
+34 653681823
www.gisland.es
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190212/da745141/attachment.html>
