[Qgis-user] North arrow in QGIS
Andreas Neumann
a.neumann at carto.net
Wed Feb 13 02:03:57 PST 2019
Hi Benjamin,
While you may be right that the UI might be broken in some cases, please
don't open the "UI element for browsing shipped images". There is a
reason it is collapsed by default: The folders contain thousands of
images (depending on your configuration). The images may reside on
network drives and it slows down everything a lot. I'd rather have this
section collapsed than having it block my interface for 10 seconds while
it is browsing and opening these image folders.
If we add a new item for north-arrow, the image browser should then
display only the folder with north-arrows and not all the many thousand
images.
@Benjamin: have you (or some students of yours) thought about
contributing to improving the UI of QGIS? It is easy to complain -
especially people from Academia are fast to complain - but they often
take it for granted that everything is free and accessible (except maybe
the papers they produce (not saying that you do that)) - and of course
the stuff they use for free should also work without glitches ....
Academia (and other trainers) are welcome to use QGIS for free, but it
would be nice, if they run into issues, that they also contribute back
(some do - some (probably the majority) doesn't).
Greetings,
Andreas
Am 13.02.19 um 09:56 schrieb Benjamin Ducke:
> Hi,
> On 13/02/2019 09:30, Micha Silver wrote:
>> On 2/13/19 9:41 AM, Frank Sokolic wrote:
>>> Hi,
>>> I think from a user point of view the north arrow is not considered to
>>> be an image so having a separate north-arrow item makes good sense. I
>>> find the current method of adding a north arrow confusing as it
>>> requires the user to know the following:
>>> (a) North arrows are not added by clicking "Add Arrow"
>>> (b) North arrows are added by clicking "Add Picture"
>>> (c) North arrows are in the "Search Directories" section of the image
>>> properties but this section is collapsed by default so the user has to
>>> know that they must open this section and then scroll to the north arrows
>> I have no problem with the "Add Picture" approach but it would be better
>> to have the "Search Directories" displayed by default. It's not at all
>> obvious (surely not to a new user) that you have to expand that panel in
>> order to find the north arrow images.
> Some empirical remarks, from observing users
> that understand cartography, but not technical
> UI design decisions:
> Out of the ~200 people that I have trained on
> QGIS, ~100% did have trouble finding a way
> to insert a north arrow into a map layout.
> About ~75% of them clicked on "Add Arrow",
> and some of those were quite satisfied with
> the result; so in the future, expect to see many
> maps created with QGIS that have ordinary arrows
> adorning them, which more or less point
> northwards!
> There are various reasons why the current
> method does not work in practice:
> - people do not think of a north arrow
> as an ordinary picture; they think of it
> (and rightly so) as a cartographic element
> with the same rank as a scale bar; after
> all, like a scale bar, it has a dynamic
> property (its orientation)
> - some think of a "north arrow" as an
> "arrow" (which leads to: see above)
> - "ordinary images" are inserted into a
> layout by using the "Add Picture" function;
> that leaves people wondering where to find
> north arrow pictures, and they wander of
> to Google to find some...
> So the complete mental chain here is:
> north arrow -> picture -> built-in picture
> ... and that just leaves people totally
> stranded (never mind the fact that the UI
> element for browsing shipped images is
> collapsed by default, so people will just
> scroll past it; and that there is a lag
> of sometimes several seconds between clicking
> on the tiny triangle and getting to see
> actual images; so people will scroll past
> it again; and that "Search Directories" is
> a UI label that most people don't associate
> with anything useful...).
> In my view, this is a part of the UI that is
> conceptually broken in about half a dozen places,
> and there should be a dedicated north arrow
> tool "Add North Arrow", exactly where it should
> be, i.e. right next to "Add Scalebar".
> Best,
> Benjamin
>>> I don't find this very intuitive.
>>> Regards, Frank.
>>> On 2019/02/13 09:12, Andreas Neumann wrote:
>>>> Hi Hugo,
>>>> I was initially also puzzled by the fact there is no "north-arrow"
>>>> item for the layout. But if you think about it a bit longer, than you
>>>> realize, that it is just as efficient adding an image and synchronize
>>>> the rotation to one chosen map, than it is to add a north-arrow,
>>>> choose an image and synchronize it with a chosen map.
>>>> Do you really think, having a separate item for north-arrow is more
>>>> efficient? How many clicks do you save by having a separate item?
>>>> Greetings,
>>>> Andreas
>>>> Am 13.02.19 um 06:11 schrieb Hugo Paul:
>>>>> Good day
>>>>> I was wondering if there is a more efficient method for adding a
>>>>> north arrow to a map layout in QGIS than adding an image?
>>>>> Something as simple as just clicking somewhere add -> north arrow,
>>>>> and then being able to choose various styles.
>>>>> Is something like this available?
>>>>> Thanks
>>>>> Hugo
>>>>> *Disclaimer*
>>>>> The information contained in this communication from the sender is
>>>>> confidential. It is intended solely for use by the recipient and
>>>>> others authorized to receive it. If you are not the recipient, you
>>>>> are hereby notified that any disclosure, copying, distribution or
>>>>> taking action in relation of the contents of this information is
>>>>> strictly prohibited and may be unlawful.
>>>>> This email has been scanned for viruses and malware, and
>>>>> automatically archived by *Mimecast SA (Pty) Ltd*, an innovator in
>>>>> Software as a Service (SaaS) for business. *Mimecast Unified Email
>>>>> Management ™ (UEM)* offers email continuity, security, archiving and
>>>>> compliance with all current legislation. To find out more, contact
>>>>> Mimecast <http://www.mimecast.co.za/uem>.
>>>>> _______________________________________________
>>>>> Qgis-user mailing list
>>>>> Qgis-user at lists.osgeo.org
>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Micha Silver
>> Ben Gurion Univ.
>> Sde Boker, Remote Sensing Lab
>> cell: +972-523-665918
